Help Slyrocket In Call volume low?
lilflippy
Hi I just bought a Att Skyrocket I like the phone but the in call volume is very low.
Is there a way to increase this?
What other att android phones have a loud in call volume & Speaker?
The volume on mine is more than loud enough, both regular, on speaker, through the Bluetooth (Blue Ant) or through my Jawbone Jambox.
any idea what your signal strength is? There is an app called network signal info that can show you signal strength
I have seen a few posts about this but have had no issues on any of our SR phones...this may be a defect, or could be low network signal and or quality in your area. If it is a quality issue no phone will have better in call quality. A friend and I just tested this actually at his house with a skyrocket, inspire and GS2
I went to ATT today. I went to buy the skyrocket BUT compared to the iPhone, the volume was atrocious. Is there a fix? Had the volume cranked up but it was muddy trying two of them. I left with nothing and decided to come here for answers if there are some. Thanks.
As I said in the post above... no issues with in call volume.
Are you guys turning it up with the volume rocker while in call. It is set pretty low by default
I poked around this and other places about the call quality issue. Too bad such a well designed phone left out an ingredient so central to its usefulness. I won't buy it.
There is no call quality issue with this phone. Yes the volume could be higher but it is just fine at highest volume. Speakerphone is fine too.
The only controls I have found are under Settings, Sound, Volume............
You have individual volume controls for incoming call, media, System and notification.
The rocker adjusts the incoming call volume. You guys really think the call volume is low? If I turn mine to max, its overpowering.
HOW DEEF ARE YA?
Honestly, it should be more than suitable. Turn it up. It doesn't go to 11 but 10 is fine.
You must be in call to change the call volume. While on the call press up on the volume rocker
