Biaviian
I decided to look for a new SMS/MMS application because the stock app won't let me see the entire recipient list in a group message (is there a way to do this). I found GoSMS which seems like a great application but I can't get the LED status to work. I suspect this is because I use Light Flow. Can somebody tell me if Light Flow is causing an issue with GoSMS (even though it isn't supported by Light Flow). Or can somebody point me to a better/different SMS/MMS application that will allow me to see the entire recipients list and use the LED notification?
