Root SMS Problem?!
CTM
Member
I am running Gingeritis v1.0 with the mr2.5 radio and everything is perfect except i cant send sms to my girlfriend who also has a thunderbolt (stock). Im confused because every other sms will go through to anyone else. May be a ROM issue because they would go through before when i was running cm7. any help would be appreciated.
Put your phone in airplane mode for a minute, then switch it off. If that doesn't work try wiping cache and dalvik and reflash the ROM. Sometimes flashing themes or mods can screw little things up, wiping the caches will remove any add on's you may have flashed so you can go back and flash them one by one until you find the one that is messing up your SMS.
Switched to bamf 2.1 and everything is pretty good so far ill probably just stick to this one for a while
ah hell...now BAMF is doing it, gonna wipe everything then flash again. you think it could be the radio?
