So how exactly does the HTC Duo Camera work?
Phases
NO LONGER ADMIN
I know there's a camera thread already but, how does this function actually work? It's it taking two pictures, letting you pick which to use the focus from, or adding minor depth for more realistic picture or what?
From what I've read on the camera, the main lense takes a normal photo. The second camera takes its own image, and by comparing the two it can calculate depth in the image. The second photo is deleted, but the depth information is stored alongside the main image. Then when you load up the image editing software and choose where to 'focus', the software instead cheats by blurring everything but the stuff at a specific depth.
Other companies like Nokia and Samsung have their own versions of this, apparently, but they instead just take multiple images at different planes of focus and you can later choose which one you want. That technique would take up significantly more storage for images, but you really do end up with an image that was focused on the object you wanted, rather than a partially blurred image.
That sounds pretty sweet. I wonder how it works in the real world though.
HTC guy was talking about using all new sensor in this phone, and how it was WAY better than the previous One and Onemax.
