Root Soft Brick? Help me out plz?
EManU3LXX
Hey guys, I recently rooted my phone, and I was installing fonts (using JRummy's app). When I rebooted, it got stuck on the ZTE screen. I wasn't flashing roms, so I don't have CWM installed, although I CAN get to the FTM screen and the Stock Recovery.
I've tried using the Software Update Tool, but holy balls it takes a while to start up... everything about it is slow as hell!
I also tried Junkie's AIO tool to install CWM and a custom ROM, but that doesn't work. It says "Process took too long, Check Drivers" when I check drivers, nothing pops up. WTF?!? I've tried two computers, different USB cables, and have installed drivers multiple times. I'm getting quite tired of this, anyone care to help me out?
I've found some information on the difference between FTM & Download (bootloader) Mode, but at the same time, I can't for the life of me, put it in download mode...
If you have adb enabled on your device, it is possible you can connect from the zte boot screen. If you do not have it enabled, it will be very difficult to enable it since you can't boot to android.
Install adb in windows, open cmd.exe in windows, type "adb devices". If your phone shows up, we can get you sorted out.
By the ZTE boot screen do you mean the boot animation? And I'm pretty sure I did, let me check it out right now
Yea, from the ZTE screen I can't get ADB to detect it. I CAN however boot into FTM, and start the ZTE software update... BUT, it doesn't ever start downloading.
If you can't get to adb, the update tool is your best bet. However, since you didn't root or install custom recovery you should be able to send it to zte for repair.
It is rooted, it just doesn't have a custom recovery, so I'm trying to get the Update Tool to work... now it just doesn't download the update... stays stuck at 0%.... this sucks.
I think you may be sending your device to zte. Too bad you didn't install cwm lol. Next time ;)
May as well call them, they might help you out. I believe it is your only option at this point other than getting a new phone.
The only one we have is the b11 update, but it is only patches so it probably won't work. You could try it...nothing to lose lol
I need to leave for a while, maybe someone else can help you find it if you can't on your own. I will post a link if you don't find it before I get back.
the update tool is your best bet... the fact that it doesn't download may be due to malware on your pc or a slow internet connection.. but if your phone is capable of FTM mode it is the way to go. But SuperR had a point tho, if your phone is rooted, which method did you use to root it? you should have adb enabled on your phone unless you performed a factory reset in your stock recovery in a attempt to repair your phone... when the boost mobile boot animation comes up you should have access to adb... and if you do, you can use junkie's tool to flash custom recovery and from there just flash over a custom rom and solve the problem in a much cooler way:)
The download tool eventually worked. At first it was taking like a half hour to start up and do ANYTHING So I was like f this and I went to go chill with my bros. I got back and booted up my PC and started the software and it took less than a minute to startup and said something about updating the application so I updated and it all worked after that. I rooted and installed CWM made like five backups and installed SupeR's rom.
