Was trying to flash a new rom onto my Bionic but the file was a bad rom. The file didn't install and i forget the one easy step of setting the backup. The phone no longer boots (stuck on black screen), and resetting to factory defaults hasn't been working.
I've been trying to reset using the RSD lite flashing method.
Every time i try to reset it gets stuck at 1/20 mdm some file not working.
The one thing i've noticed is that in the fastboot i have battery low and cannot program. Does this just mean i need to charge the battery somewhere and it should fix the problem?
