dudeman1996
Android Expert
MMXTREM from 4pda.ru has customised the original SwiftDroid ROM from Mur4ik:
Added 3rd party apps:
Removed Apps:
Fix: Voice search button, camera, autofocus, LED network and Wi-Fi is now permanently green.
Data - free, free space in the System - 68 megabytes (for manual installation of applications!)
Screenshots (taken from 4pda.ru):
How to install:
AppLanet
Opera Mini
Balanced
QQPlayer
MusicPlaer
DroidWall
Gmail
Youtube
Moon + Reader
S2E
WiFi Manager
Balda
Voice Search
Calculator
MyPhoneExplorer
Documets to go
Skype
SystemAppRemover
Advance Task Manager
Fancy Widget
Mail.ru Agent
LauncherProPlus
DioDict
TypoClock
Widget Posts
Widget notes
Widget frame for pictures
LG Keyboard
Yandex Maps
Selecting the screen
Spec. Features
Fresh host
New large pack of wallpapers (hi a_black_cat)
Subject Senc (retouched interface)
Were also modified some system files and widgets!
New butanimatsiya.
Updated some applications.
Opera Mini
Balanced
QQPlayer
MusicPlaer
DroidWall
Gmail
Youtube
Moon + Reader
S2E
WiFi Manager
Balda
Voice Search
Calculator
MyPhoneExplorer
Documets to go
Skype
SystemAppRemover
Fancy Widget
Mail.ru Agent
LauncherProPlus
DioDict
TypoClock
Widget Posts
Widget notes
LG Keyboard
Yandex Maps
Spec. Features
Fresh host
New butanimatsiya.
Removed Apps:
Twitter
Facebook
Terminal
Spare Parts
Development
Androidify
Google Maps
Mini Music
Google Voice
Stardroid
and more!
Terminal
Spare Parts
Development
Androidify
Google Maps
Mini Music
Google Voice
Stardroid
and more!
How to install:
1. Download the Soft-ROM .zip file from here (MultiUpload) or here (MediaFire). Copy the folder inside the .zip file to SD Card/clockworkmod/backup. IMPORTANT, make sure that you do NOT put the contents of the 'Soft-MOD' folder into 'backup' you must put the Soft-ROM folder into the 'backup' folder so it looks like this:
2. Reboot your device into recovery mode by holding the Home button and powering on the phone, making sure the power button is held whilst the LG logo shows. SwiftDroid v1.5+ users can hold the power button to bring up the phone options, then tap Reboot>Recovery>OK. If you don't have recovery installed, then follow the instructions here under the ClockworkMod Recovery section.
3. Now you're in recovery, use the volume up and down buttons to navigate up and down the selections, the call button to select, and the power button to go back. Select backup & restore>backup. This will backup you're current ROM in case anything goes wrong, this could take a while.
4. Now select backup & restore>restore>Soft-ROM>yes. Soft-ROM will now be installed. Press the power button to get back to the first screen and select reboot phone.
5. You're phone will now reboot with Soft-ROM installed! Enjoy!
