Root Solution for white screen problem after flashing custom roms
amritk86
Hi my friends ....my phone gave me a total white screen after every install of a custom rom and it works fine without locking my screen with lock screen it returns me a white screen ....
Now I have resolve this issue with my phone hopefully its work for others
1 ok here we go simply flash a custom rom
Now let the phone boot after complete boot press power button for locking screen, now press again power button to check if white screen appear
3 ok now go to recovery mode now I hope u made a full backup of ur stock rom before installing custom rom ..ok now go to backup and restore menu click ok then chose advance restoe option - click ok - now scroll down to ur stock roms backup now u see some options like restore boot, restore system
4 now simply choose restore boot and let it restore
After restore simply reboot ur phone ....I hope ur problem solved....
If the person would have installed a total different Firmware from SP flash tool,
this may not necessarly be the case as there was no backup before installing :D
You just need to redownload, and reflash either of the flashable firmwares
Stock, UB Series, Gionee formware etc etc
Yes you are right sir in that case this mathod does not help any one plzzz sir provide a full solution for that.....
