Root (Solved) Binding adapters (Wifi to Other Tether)
rhino889a
Android Expert
After looking around i havent been able to find what i am looking for
Often i am without having metro service for the month
So i use wifi often.some of the spots i can go have weak wifi
One spot is so weak and touchy
Moving 6 inches losses connection and the connection is super slow
But i can put my phone in a spot and it gets huge download speed
But i cant actually use the phone when its in that sweet spot
Have a couple motions wondering if i can use one as wifi repeater.
Like bind wifi to one of the other radios
So i can put one phone in The Spot and actually use another motion from close by
Has anybody come across anything like this.
Not sure if thays supposed to be the name of an app
All the apps i have came across are designed to tether the carrier data and not wifi.
I have some more time to waste so hear it is
So i found i can use one motion as a repeater
Put foxfi on one motion in bluetooth mode
It repeats wifi signal through bluetooth to my other motion which connects using pdanet tablet
For the most part it works great
Speeds are high
Browser ,torrent most things work
Playstore wont download
But is very usefull
