LfcFan1977
Member
Very odd that you get the cdma, unless that somehow means it is now simlocked (no idea about simlock though).
Dan/others may correct me on this but it is possible that it is charging but without LED.
Im not brave enough to tell you to pull the battery now, so I will leave that decision to you or better android educated member.
I am not being of any help here, however, I see you are s-off.
Have you got android-sdk on your pc.?
If so, are you familier with typing command prompts?
but Teppic stated that flashing this would not restore the misc partition. So I opted to cut my losses and start again.
