Help (solved by me)x8 freez on sony ericsson logo help
key4you
try to install app2sd
after install it reboot nd stuck on se logo.noting happens after 30 min.:(
need help
i have xrecovery install its working nd i try to reset factory settings but not working freez on se logo need help.:(
Hi,
If xRecovery is working, just flash the backup from your /sd/xRecovery/backup and you are good to go.
go to xRecovery menu>backup and restore>restore
cheers :)
Hi,
cheers :)
got no back up so i use
Update_Service_Setup-2.11.4.11.exe
for restore and it works for me now i have app2sd nd xrecovery both
nd 1 made new back up first so now i able to restore it.thanks.
Im asking everyone here...My X8 stuck the SE logo..after i installed the CM7...but before i install it, i didn't follow the instruction..i just install it through the xRecovery. and then switched off the phone. after that,i turned on my phone and its stuck on the SE logo..i didn't even can access to xRecovery..If can access to there,i will restore it..but i can't because i didn't even can enter the xRecovery... when i do the way u all have given, theres nothing change except the same stuck on SE logo..what should i do... Is there any way to solve this problem.. please...i will be appreciate with any of your help... i just feel so sad with my X8...
