Phone details
HTC Desire
Rooted, S-OFF with custom partition
Running CM7
SD Card with 1Gig Ext 3 partition for all my app's
All the rooting and flashing Rom's was done a couple of months ago and all has been running fine since then.
For the last 2 or 3 days several app's have been closing themselves within 20 - 30 seconds of starting - they are not "force closing" and giving me any kind of notification - they will just hang for a second or two then it will bounce me straight back to my home screen.
I have a few .avi files on my sd card and usually play them with Moboplayer - last couple of days it will only play 20 - 30 seconds at a time before closing itself without warning. I can restart the file and it will last for another 30 seconds or so before the same thing happens.
Also have a couple of games that have been doing the same thing - a 3D baseball game and a 3D golf game - similar story - 20 - 30 seconds in and they shut down with no warning.
Other games will play ok - like a 2D tower defense game and my music seems to play ok.
Can anyone suggest a program / app / log or report I can use or access to try and pinpoint what is causing this?
It seems like apps and games that need a bit more juice from the phone wont run properley - .avi files and 3D games. I have been able to run these games and play the .avi files previously without problems - just in the last couple of days I have had problems.
I had previously been using some of the different CPU govenors within cyanogenmod settings but to the best of my knowledge they are back where they were previously.
So far I have tried fixing the permissions, wiping the cache and Dalvik cache from recovery.
Anyone know of any apps or logs I can refer to in order to find out what is causing this?
Any help would be appreciated.
HTC Desire
Running CM7
