Exiled_SouL
Problem Solved,follow this guide
http://androidforums.com/desire-support-troubleshooting/365476-usb-brick-fix.html
Hi,All..yesterday i flashed gingervellain 2.5 rom without any problem but after i tried to browse the market,things went south.it started reboot my phone and bootloop
then i tried to restore my nandroid backup from recovery and got sd card mount failed+i was unable to flash and android sdk also failed to recognize my device after that so no adb shell
but in windows device manger when i connected my phone usb via fastboot it shows my device was connected but unable unroot with ruu.exe from pc.
i was usb bricked before but fixed it with adb shell n terminal emulator but this time it's not working,i tried xda n this forums possible usb brick fix for rooted(s-off) nothing seemed to work..
then i got desperate and unrooted my desire with pb99img.update from hboot as i thought it gonna fix the brick now things are more messed up and i am stuck on stock froyo2.2 ,s-on without any usb function.
then i tried the unrooted(s-on) desire usb fix and stuck
Copied the exploit binary (rageagainstthecage-arm5.bin), the flash_image and modifed mtd0.img to the sdcard via an external card reader.
tried to Copy the files to the Terminal app data directory using the command
cat /sdcard/rageagainstthecage-arm5.bin > /data/data/jackpal.androidterm/shared_prefs/rageagainstthecage-arm5.bin
It says invalid directory/file not exist
this is the thing i did in past 10hr still no luck..now my question is can i fix this problem by myself or did i just permanently usb bricked my desire sorry for long post i need help badly and pardon my English
DDDDD
