Hello.
I want to preface by saying I genuinely have looked - all day - and am still very confused.
I've been on iPhone since since the 3g, I loved it, but I wanted a change, and the GS2 gave me reason to change. I was massive into jailbreaking and customising, so naturally I want to tinker with this phone.
The problem is I don't have a clue. I know nothing about android, and I know nothing about rooting ect...
Any of the many guides I've seen all say different things, I can't seem to find one clear cut definitive guide.
I don't know what info you need so I'll just list what's in the "About Phone" menu.
Model Number - GT-I9100
Android Version - 2.3.3
Baseband Version - I9100BUKG1
Kernel Version - 2.6.35.7-I9100BUKG2-CL342890 root@DELL102 #2
Build Number - GINGERBREAD.BUKG2
It was bought in Ireland today on the Vodafone Network.
I know the pros and cons for Rooting - as I said I have been researching as much as I could, but now I just need pointing in the right direction to a guide that will suit my needs exactly.
Also, I have ordered a 16gb sd card for it, so I will have it soon, but I do have a 2gb one if that's any good for now? - Does the sd card retain the root or can all files be deleted off it after?
I thank you in advance for your help.
