RunamuckRez
Member
Hey all, was hoping I can get some minor help with a SetCPU issue (and overclock widget issue, I tried both).
Some background, I rooted today using the one touch method, and after reading about the different roms I decided to go with Frisco's advice and install xtrRom. A few minor hiccups in the install process but I'm up and running for the most part (still tracking down all my apps to reinstall to the SD card but thats another topic). I did also install all the optional modules (LWP, stock apps, and htc stuff), and made sure JIT was turned off (I'm a heavy pandora user). The next thing I set out to do was to overclock this thing. I realize that xtrROM doesn't need overclocking, but I wanted to see if I noticed any differences from stock. So I buy and install SetCPU and then run it and I get to the SU Request screen and nothing happens. Any ideas why this might be? Did I screw something up in the flashing process? At the very least I did a Nandroid backup so I can always restore if need be ( and I still might, I really miss the HTC widgets). But I'd like to get this up and running before I decided one way or another.
thanks for the help.
Rez
Rez
