Root Some questions before I flash cm7
rbby228
Member
Ok i wanna flash cyanogenmod 7, but I have some questions first is what's the difference between nightly 19 and rc2, and which to flash. And Second which hdpi gapp do I flash?
Thanks in advance.
I just flashed CM7 RC2 last weekend and it was VERY stable and everything worked, except HDMI. 4G and and a quick signal lock on GPS were the most important things to me. I'm not sure if all that is working as stable in the nightlies.
FullHDMI in the Market offers full HDMI mirroring at $3. It works great even with my cheapo eBay cable (which didn't work with the stock HDMI out feature).
I discovered after trying CM7 (my first AOSP rom) that I'm a true, blue Sense UI type of guy so I switched back to Myn's rather quickly. But CM7 was impressively stable and working on the Evo.
Is it just me or is Gingerbread not that big of a deal? I didn't notice too much that was overwhelmingly different or better than Froyo.
Thanks! Lol the main reason I'm installing cm7 is so I can play roms on my tv while using a wii mote when I'm somewhere boring. Ill just set it up then make a nandroid then just flash the nandroid when I need it for those purposes. Besides I need a change from mikfroyo anyway
Thanks in advance.
RC2 is the most recent semi-stable release. It falls between #13 and #14 I believe. #19 is the most recent nightly release. I am currently running Destroyer which is based on RC2 but also have a nandroid that I keep updated with the latest nightly. CM7 is the most customizable rom I have seen out of the box. Destroyer added a lot to the theme changer and themed alot of the apps included in it but has all of the settings that RC2 has.
