Liors
Hi,
I just got my Huawei watch and it is great!!
I have some questions and tips that it will be great if you can help me with and I couldn't find answers to.
1. Charging - what is the best way to charge it in order keep the battery life? like everyday few mins? everyday to full charge? let it drop until X%?
2. Always on option - is there an option to make it sleep at night? like I like this option very much, but as I don't sleep with it, I think it is better that the screen will be off at night.
in addition, do it harm the screen if always on working all the time?
3. Reset - do you reset the devise occasionally? like in purpose. I mean, on my Samsung S6 i know that once in a while I need to reset it to get a better performance.
3. Steps tracking - I was with the blue moon face and noticed that the steps showed is updated after few seconds, meaning that let's say I walked 50 steps, I stop, look at the watch, see the old steps count and after 2-3 seconds it is "jumped" and updated to the new count. in addition, if I stop, wait this few seconds and look at the watch, the count is ok - is this normal?
4. fitness app - which app to use with it that will sync the best with my phone? I installed Google fit and its not doing the job good. it looks like it count steps from the phone and not the watch, or mixed it together, In addition the distance and calories count is way not true, like it show the distance far low then the true (I updated my height and weight, over the app and on the watch) and the calories far more then it is.
In addition I installed the Huawei wear app and it looks much more accurate, showing the steps as the watch, and separate it to walking and steps, distance is accurate and calories as well. but the app doesn't look so good and looks like it missed a lot of other option.
In addition, I don't understand why the Huawei app on the watch is not showing distance but just steps count.
So, which app do you use? I basically want a nice app that will show my daily usage and if can, that will sync with the heart rate measure that i can take from time to time.
Can I sync it to S-Health that I have? or please recommend for another app.
5. Is there any nice watch face that shows not only the steps count but the distance as well?
6. Any other general recommendations?
Thank you very much for your help.
Yes, a lot of the aftermarket faces I have have an option for how frequently to update steps and/or weather.
But seriously, it's built in to protect the screen, and it works when it is on the charger and for standard ambient mode.
