Root someone please help!!!
extremejoe
tonight i rooted my desire with clockwork
made a nandroid backup which was successful
flashed oxygen rom
played around with it for an hour and i don't like it
went to restore nandroid backup of my froyo 2.2 with sense
and i got the error md5 mismatch
can someone please help me fix my phone?
or give me the location of a stock 2.2 froyo with sense
Its corrupt backup. You will not be able to use it. You will have to re-flash whatever rom it is.
This is very rare, but probably sd related.
i've installed leedroid 2.2 with sense and back up and running now
there's titanium in the app drawer - can i use that to do a full back up of the phone - operating system and everything?
That's the only way to do a full image backup. All the other ways will just back up apps and settings etc
You could try another nandroid backup and restoring to see if it was a one off. Nothing is harmed if you get the error again. The alternative is to try another SD card - that may be the cause
This ^^
Anyway these MD5 checksomes are rare. Ive had one before and it was a dodgy file system on the SD.
You can always mount it on a PC and if it prompts to check for errors, tick all teh boxes and go for it.
EDIT> googling, found you can nandroid via adb, but it doesn't look like you define a location for it (so goes to default).
If you could define a local backup location of a remote device, it could be useful.
you can but you need s-off to flash them back
you just create a folder in sdcard, for this example i will use adbnand
cat /dev/mtd/mtd1 > /sdcard/adbnand/recovery.img
cat /dev/mtd/mtd2 > /sdcard/adbnand/boot.img
cat /dev/mtd/mtd3 > /sdcard/adbnand/system.img
cat /dev/mtd/mtd4 > /sdcard/adbnand/cache.img
cat /dev/mtd/mtd5 > /sdcard/adbnand/data.img
probably worth doing misc aswell for usb brick fixing
cat /dev/mtd/mtd0 > /sdcard/misc.img
you can then keep that on your computer
you use fastboot to flash them
fastboot flash recovery c:\adbnand\recovery.img etc etc
thanks to droidzone for indexing this info on xdadevs
This ^^
i dunno how to use adb - i'm rubbish at programming
if i did a nandroid backup of leedroid now - and restored later
would that work?
yep. You can either miount as usb mass storage via recovery (recommended) or via android as normal.
