ErisEscalavee
OK, check this out. I rooted my Incredible, and I had problem after problem with rooting because of what I THOUGHT was an SLCD issue (I lost all function of my touch screen whenever I flashed a ROM or kernel, even if they were compatible with both screens). After 3 days I finally found a combination that worked.
My husband wanted me to root his phone, and I wanted to physically see the difference in speed between rooted and stock while doing a Web search. Well, when I put the two side by side while on Google, there was a blatantly obvious difference in the screen color. My screen had a pink tint and his was crispy white, to the point that it almost hurts the eye to stare at.
So, I downloaded the "mirror" app (which is just a black screen that shows your reflection) and yep, sure enough, I had a bit of brightness on mine, and his was just black as night.
Both of our phones had the 003 under hardware, which is suppose to mean the screen is SLCD, but mine is clearly AMOLED.
I am thinking, since they were both refurbs sent as replacements, that I got a phone that was originally produced with an SLCD screen but it got replaced with an AMOLED.
Could this be the reason that when I flashed a ROM I had no touch screen function? Could there have been an incompatibility issue between the original hardware and the replaced screen that got triggered by trying to flash a ROM?
This is kind of blowing my mind right now...
