Help Sony PC Companion (No phone/tablet connected)
KingTei
Hello folks,
My Sony PC Companion won't recognise my Xperia Z tablet saying that "No phone/tablet connected". My laptop is a Toshiba Satellite 32-bit running windows 7 ultimate.
Please help. Thanks.
I GET THE MSG BELOW WHEN I TROUBLESHOOT:
Program Compatibility Publisher details
Issues found
Incompatible ApplicationIncompatible Application
PCCompanion is incompatible. Detected Detected
Fix application PCCompanion Completed
Issues found Detection details
5 Incompatible Application Detected Detected
Provides steps to fix the incompatible application.
InformationalCompatMode
CompatMode
# WINXPSP2
InformationalUserVerifySolution
User Verification of Solution
Verify_YES
I'm using PC Companion (v2.10.174) on a Win7 Ultimate system, albeit 64bit, so it should work fine on the 32-bit version.
Make sure that you have the most recent version of PCC installed by downloading it from here. The error msg posted appears to suggest that the software needs to run in XP Compatibility Mode, so I wonder if your version of PCC is an older one?
It's fine on my Win 7 Pro 64-bit lappy, though sometimes it can take well over a minute to connect (which I think is to do with the 64Gb SD card in the Z).
Have you tried a different USB port on your computer?
