Help Sound Issues
xepicxacidx
All of the sudden when i went to check my phone this morning i opened up youtube to play a video and there was no sound and i checked other apps and it was the same for them i tryed to adjust the volume but no luck.wondering if anyone else had this problem or could help
Try a factory reset, if that doesn't work I would take it to Verizon for a replacement.
Make sure you return it to stock if its rooted and in the warranty period I think your covered for 12 months but you may want to look at the manual to confirm this.
