Help Sound works.... Most of the time!! HELP Please!!
swc2001
Android Expert
1st off I am on .901
I am using [K]IN3TX
Ok So I started having this issue out of the blue. Sometimes when I am doing any application that uses sound.... it wont SOUND!!
its rare but it has become a problem.
Twice my alarm has gone off..... but no sound.
I use Youtube most of the time sound... but sometimes video with silence.
Pandora... occasionally it will go to the next song..... No sound. I skip the song and sound is back.
All other applications that use sound including the phone ringing have had this phantom issue with sound.
SO I am at wits end with it. I tried Eclipse. PERFECT. Never a sound drop. Now I AM NOT BLAMING [K]IN3TX.
I think it is somthing that I did to the Rom. I couldnt tell ya what though.
I really dont want to Redo the phone again. Anybody ever had this issue?
Anybody fixed this issue.... simply?
I just dont know what to do with it guys.
Thanks in advance.
Swc2001
Just completely redid the [K]IN3TX ROM on my phone with all of my settings. So far no sign of the anomaly.
Edit: Anomaly came back after overclocking!!
Yes I have vigoursly tested this issue. And Overclocking the Bionic is deffinately the culperit!!
Once you Overclock using the Omapp method and flash the 1.2Ghz .zip is deffinately when the anomaly begins to manifest itself.
Soooo back to 1.0Ghz I go. Sorry Omapp it was cool but not worth not wakin up in the mornings in time for work and constant sound drops with all other applications including pandora, slacker, phone ringing, and texting to just name a few.
Hope this helps someone.
