Root Speed Dial not working
JMuldrow
I used clockwork recovery mod to update to Froyo on my X and it works great! Only problem is my speed dial numbers wont register. Ii will go through setup but wont store numbers. Any help? Thanks
I can't believe no one else is having this issue. Or there are only three people that care or having this issue. Either way. Uhm.
I am running a 2.2 rooted deodexed. There that should get them piling in to this thread. Or not.
Lol... I haven't experienced the problem and I'm running the same system... think your an anomaly.
I'm hurt. I've never been anomalized (uh, no such word) before. I'm in such a quagmire and so melancholy.
Anywhooooo, instead of typing the contact you need to scroll through your contacts and chose them manually. It worked for me anyway.
I rec'd the tip from DaRkL3AD3R at the Android Central forum so credit to that individual who fixed my issue.
