Root Speed Tweaks + More
Ok, Well i restored my phone back to 2.3.6 haha... Well Yea I left it on over night and it was still vibrating in the morning... lol f that... Welll Do these work for 2.3.6? if so how do i add the permissions?
Well the vibrating doesn't just go fix itself lol. Also you shouldn't download the build.prop that the guy provided since his build.prop is for 2.3.4. Just make a copy of your build.prop on your sdcard and add the tweaks you want then move the copy to the / folder in root explorer and then long press it and go to permissions and change it to match this
Read Write Execute
Owner * *
Group *
Others *
Then select ok and from there move it to the system folder and overwrite your original build.prop then reboot. It's easier than it seems lol
Thanks for this build prop. Installed via root explorer & rebooted... noticeably snappier, much smoother scrolling especially.
Thanks again!
