I believe you click on the start in the left side? Our its a picture of an as card and look through thoseI have not tried es explorer, but if it is like file expert, you have to choose "file" or "file system" then choose "internal memory" . Once in the internal memory you will be able to find the system folder. Double check that system folder is mounted as read/write when you are ready to copy the zip file there or edit the existing one.
I am not overly experienced and hope that this might help. Good luck.
Added these tweaks onto my phone and it is flying. It is on this site.
Build Prop Tweaks
1. Force launcher into memory
ro.HOME_APP_ADJ=1
2. Raise JPG quality to 100%
ro.media.enc.jpeg.quality=100
3. VM Heapsize; higher the RAM, higher the hp can be
dalvik.vm.heapsize=48m
4. Render UI with GPU
debug.sf.hw=1
5. Decrease dialing out delay
ro.telephony.call_ring.delay=0
6. Helps scrolling responsiveness
windowsmgr.max_events_per_sec=150
7. Save battery
wifi.supplicant_scan_interval=180
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
8. Disable debugging notify icon on statusbar
persist.adb.notify=0
9. Increase overall touch responsiveness
debug.performance.tuning=1
video.accelerate.hw=1
10. Raise photo and video recording quality
ro.media.dec.jpeg.memcap=8000000
ro.media.enc.hprof.vid.bps=8000000
11. Signal (3G) tweaks
ro.ril.hsxpa=2
ro.ril.gprsclass=10
ro.ril.hep=1
ro.ril.enable.dtm=1
ro.ril.hsdpa.category=10
ro.ril.enable.a53=1
ro.ril.enable.3g.prefix=1
ro.ril.htcmaskw1.bitmask=4294967295
ro.ril.htcmaskw1=14449
ro.ril.hsupa.category=5
12. Net speed tweaks
net.tcp.buffersize.default=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.wifi=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.umts=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.gprs=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.edge=4096,87380,256960,4096,16384,256960
13. Disable blackscreen issue after a call
ro.lge.proximity.delay=25
mot.proximity.delay=25
14. Fix some application issues
ro.kernel.android.checkjni=0
15. Phone will not wake up from hitting the volume rocker
ro.config.hwfeature_wakeupkey=0
16. Force button lights on when screen is on
ro.mot.buttonlight.timeout=0
17. Disable boot animation for faster boot
debug.sf.nobootanimation=1
18. Miscellaneous flags
ro.config.hw_menu_unlockscreen=false
persist.sys.use_dithering=0
persist.sys.purgeable_assets=1
dalvik.vm.dexopt-flags=m=y
ro.mot.eri.losalert.delay=1000
this is not my work, i got this from this link below
forum.xda-developers.com/showthread.php?t=1227269&highlight=TWEAKS
Loopy Smoothness Tweak
[SCRIPT / DISCUSSION] (Smoothness tweak) Android needs its priorities set straight? - xda-developers
download the zip file and install through CWM
i see a difference, and i am not responsible for what you do to your phone.
Are any of these incorporated into the ROM(s) available at this point?
Nice post aaronmy![]()
Is there any way I can do this stuff from a pc.
yes, two ways. you can move it to the SD then put it on the CPU and open it with text editor. you could also use Droid explorer and edit it there with adb.
I can't write into the folder. My phone's rooted, got CWM and Admiral Beast on there... and now, I want to unlock a few apps I have, with some tricks a buddy showed me on his phone. The thing is, it should be the same, except that he has the ability to write to /system, but I don't....
Sucks.
Except for one problem: I have used Root Browser, ES, AND Droid Explorer, and I get jack.I can't write into the folder. My phone's rooted, got CWM and Admiral Beast on there... and now, I want to unlock a few apps I have, with some tricks a buddy showed me on his phone. The thing is, it should be the same, except that he has the ability to write to /system, but I don't....
Sucks.
HAAAAALP!!!!!!
Oh, and I DID try moving the file from the sdcard. Negative on that as well. I could swear that su meant superuser, and that su rights were god-like..... I want meh God Mode![]()
Would I be able to add those tweaks to Admiral Beast .build?
Witch ones exactly are on the list that are NOT on the Admiral BeastAdmirel beast has alot of them, all the data and heapsize stagefright and all.
can someone help me with this? im not a noob at all i just dont have the sligtest clue on how to change the build.prop i found it in root explorer but cant do anything with it idk if im sapose to do it a different way id really aprecitiate it if someone could help thanks! and sorry not a good speller lol
