Splashtop on CM7 HP Touchpad?
kgirl91
I'm thinking of getting a Touchpad since I prefer its aspect ratio to the widescreen devices that dominate the Android tablet market. I would probably buy one with CM7 already installed on ebay, since they're cheaper than the brand new ones on Amazon.
However, what I really want it for is remote desktop so that I can work from anywhere. My boyfriend has had good luck with Splashtop Remote Desktop on his Transformer (Honeycomb). Can I expect to be able to run Splashtop successfully and reliably in CM7 (I know that I can run it in webOS but I don't plan to use it)? Splashtop in the Market says that it requires Android 2.2 and up. I'm new to rooting (I have an unrooted Incredible 2 that I love) so I don't really know what to expect.
Thanks!
I would also like to know this, but haven't had much luck in searching. OP if you find any relevant threads please link them back here and I will do the same
