I was just reading through some posts and saw something that intrigued me. Is there a way to flash a Sprint based rom and use the NASCAR App that they exclusively have? Kind of like Verizon with the NFL?
Interesting idea, DaveM1.
Just a thought: if you don't get an answer to that right away, you can help the community a bit by doing a nand backup of your current ROM, flashing one of the Sprint ported ROMs, attempting to install the app you want and reporting your success or failure.![]()
Question on the nand back up. When i do a nand back up of my current xtr rom will it save everything so when i flash back to this current rom i am using everything will be in place when i left it? Apps and all the settings the same?
I just may try it. What is a good Sprint rom any ideas???
