Blackout720
NEW BETTER INSTRUCTIONS AND HOW TO!
Ok so In my Last Post I Did a little how to root but didn't really say how to do the root and left some things out.
Works Wit All Qualcomm-based Galaxy S4 running Android 4.2.2 Including:
AT&T SGH-i337, T-Mobile, Sprint SPH-L720, T-Mobile SGH-M919, GT-i9505, US Cellular, Canadian SGH-i337M, Rogers, Bell, Telus, and other Qualcomm S4s.
Samsung Galaxy S4 Drivers: http://bit.ly/15kS5Cu
Samsung Galaxy S4 Root Files: http://bit.ly/129kK7W
Instructions:
Extract the entire contents of the 2 zip files.
If you are using Windows, ensure you have installed the latest Samsung USB drivers available for your phone.
Ensure USB Debugging mode is enabled on your device.
To do this go into settings and to the "More" tab then down to "About Device"
go to where it says "Built Number" and tap on that a few times until it says "Developer options Enabled".
Now go back and go into Developers Options and Enable "USB Debugging"
Connect your device to your PC via USB.
Make sure you have Download and Installed the Drivers for your Phone First.
If you are using Windows, navigate to the extracted directory and execute "run.bat". If you are using Linux or OS X, navigate to the extracted directory in a terminal and execute "./run.sh".
Now watch you phone as 2 Pop ups will happen agree and press yes to both.
And There you go, you should now be rooted!
You can also Follow along here on this video : http://www.youtube.com/watch?v=23qSKcWNL5w
I put my own phone on the line and try this for the first time my self. - CONFIRMED WORKING!
Subscribe ► http://bit.ly/YoutubeMrLegend103
Facebook ► http://bit.ly/MrLegendFacebook
Twitter ► http://bit.ly/W71rZQ
Google + ► http://bit.ly/V57ajp
Instructions:
