colinpd137
Iv'e been on the hunt for literally.. months, trying to find a tablet that I can use for my small business that I can use as a Point-of-sale or pretty much a cash register with my square reader. As i'm a small business square is really beneficial because of the flat rates & no monthly fees or contracts.
Right now i'm on the hunt for a GALAXY TAB (sch-i800) which I "think" will work, but want to know if there are other tablets out there that are affordable & ACTUALLY WORK! This has been really hard thing to dig up & only found bits & pieces. Here are the "requirements" from Square:
Google Android 2.3 or higher (Honeycomb or modified versions of Android are not supported)
A 3.5mm headset jack with microphone (audio jack adaptors are not supported)
A screen size specified as Normal or Large (Small screen sizes are not supported)
Location services enabled
Access to Google Play
If you have successfully used square on your tablet will you please list it up here? It would be great to compile a list of working android tablets usable with square because there are NONE out there.
