quick question,
I was on xda right before it shut down last night/this morning, and I remember reading that SRE v1.3 isnt overclocked? Can you confirm. thanks
quick question,
Wow!! Thanks!
Is this the file from last night, or does this one have the blue bubble wallpaper added back into it and if so are there any other things added to this?
How can I tell if I'm over clocked and what I"m over clocked at? I did not install set cpu from the Titanium backup... didn't think it was needed from reading your updated post on XDA
FYI = Add blocking is not working
Running fresh JF6 --> deleted set cpu ?script? from earlier version of SRE --> JH7 --> SRE 1.3 --> Titanium back up with all past data and apps except set cpu
It's NOT overclocked, that was an oversight, its not fixed yet, but will be soon.
another oversight, fixing right now... new 1.3c will be up in about an hour.
WOOHOO! I can't wait. Could you tell us what will be included in 1.3c?
Thanks DG, I was hoping you'd post something on here, I was watching the thread on XD last night waiting for the update and this morning when it was down I was bummed. I love v1.2.3 and I can't wait for the update 1.3c. Awsome work as usual.
What is the meaning of "DO NOT flash over, flash stock FIRST!"?
Is that mean I need to flash stock ROM first???
Thank you. Where can I get stock ROMs? Is it has to be the original rom? I'm confused.
The version on the websit is it v1.3c or 1.3? I click on the download and it looks like it is 1.3.
its not up yet
running stress tests on UV clock speeds...
highest mV is 950 at 1.2GHz
just ran stable for 10min on setcpu stress test... 45C battery temp, lost 1% battery
its not up yet
Thanks all. I will wait till xda works again! I'm so excited =P
