Anyone know a stereo headset that will allow me to skip a song when squeezing a button? So far I been using the cliq's headset but it only allows to play and pause a song. I need to SKIP to the next song so I dont have to trun the phone on to do that.
Anyone found one?
i'm using moto rokr s9-hd. can skip to next song, previous song, pause, play, turn vol up/down, and talk on the phone.
Just curious, why would you want to use a wired headset when you have a device with a2dp built in? Altec Lansing makes a wonderful stereo bluetooth headset as well if you want to check out alternatives. Just might spoil you.![]()
I just got the bose on the ear headset for Christmas. I am not sure if it has what you are looking for, I wanted the ones without the controls in the cord, but the sound quality and noise isolation is incredible. I know Verizon and Best buy both sell the set with the phone controls built in to the cord.
Well, I do have the motorola bt headset BUT with the bose in-ear buds(I modified that) so I am spoiled with great BASS which I love. But, using bt headsets and wifi does NOT work very well at all when streaming tv shows with jetflicks. The shows pause evry few seconds, I have to stream using 3g which works when I have a good signal which I don't! So much for verizon being such a great 3g provider. Anyways, bt headsets are also useless since the droid will not let you skip a song in pandora or slacker. So I figure why bother with it and waste battery power. When I had the palm pre, than it was worth using a bt headset. Skipped songs on every app I had on the phone.
FYI, I have no problems skipping songs in Pandora
