Thanks guys for the info. I am still uncertain about doing this, I want to be able to play with overclocking, have wifi tethering and possibly be able to do further updates past 2.2 and maybe different with themes.
Also does stock 2.2 only go to 600mhz or does it go to 800?
Scott
OK I am going to give this a try, can you explain these steps?
4.) Run command prompt (Start->Run then type "cmd" and hit enter)
5.) Change directories to your C:\ root directory (cd c:\)
6.) Type in "md5sum SPRecovery_ESE81.sbf"
7.) Make sure the sum of the image is EXACTLY 9b6a336cd8f067d4487935468c758d89
Also will doing this clear all my data/info like contacts, text, apps, call log?
have you tried the Sapphire roms?
Scott
so i will lose my info, how do i get it back, mainly my contacts and apps?
scott
now what is the best way to update to 2.2 and also to overclock? also will my contacts be saved?
If you followed my guide then you are on 2.2. All you need to do is install a kernel and get setcpu off the market
