Root Stock Boot Animation
rarechaga
I just sbf'ed back to stock froyo from Apex 1.4 and the boot animation is still the Apex one. Does anybody have the stock 'red eye' animation so I can set it back completely to stock?
Yes, you'll get it back with a factory/data reset, but if you want further control over your animation:
Here you go: https://market.android.com/details?id=com.jrummy.animation.changer&feature=search_result
As cool as this app is, it is to change the behavior of screen transitions, not the boot animation. I guess the best bet is to do a factory reset unless someone happens to copy it it and post it somewhere.
Edit: Just found that jrummy does have this, link below, that gives you the ability to change boot animations (even randomize every time you boot!), I am not sure if it has the stock droid animation though.
https://market.android.com/details?id=com.jrummy.roottools
