Root Stock Kernel
gregg098
Right now Im on stock 2.1 rooted. A few little issues I had with other ROMs and overclocking are totally gone which is great. I would like to try some different kernels, however, to see if it was the ROM or just the kernels I was using.
Anyways, how do I get back to the stock kernel if I change to a different one? If I have a recent nandroid, can I just restore one of the partitions? I would like to retain all of my data throughout the process so Id like to avoid doing a full nandroid restore if possible should I have problems and just restore the kernel.
Thanks
If you have a current Nandroid backup of your 2.1 Stock with the Stock kernel, you can change kernels to do the testing you want to do. If you want to go back to stock, just restore your entire backup or simply the "Boot" partition. That doesn't change your data files, it doesn't change the system files...just the kernel. You have to do the "Boot Partition" restore in "Advanced Restore" in SPRecovery. Just make sure "boot" is the only option with an * next to it and then restore.
