Help Stock ROM?
reilus
I saw a stock FROYO 2.2 for Optimus M ROM somewhere and I cannot find it now. Does anyone know where one is?
I had problems getting ROM Zero to work and I am going to flash an older version and see what happens with that. I could not install applications from the market. I could not get the buttons home+down+power to do the factory reset either.
I found this here: http://androidforums.com/lg-optimus-m/244756-lg-optimus-m-development.html
But, do I just zip all the files or what?
when you first flashed did you make a back up of your stock rom by chance?
I am guessing from your question you did not but thought maybe you had and forgot?
No, I already ****ed up my stock rom before. I moved some applications and then, when I moved them back, they would not work. I want a fresh rom.
Hmm okay. Go to LGs website. Download the LG updater. And run it. That should work. If it doesn't follow andyo70s instructions from his post called " who wants to downgrade. Look here if you do!LOL"
LG didn't work. Also, I think the downgrade has been depreciated. I've read some talk about that over the past few days. asadullah worked on it and got most of the functioning back.
