Root Stock RUU for desire Tmobile uk?
Tried a few different stock ruu's to unroot my phone but the all give the same signature error at the end of the process.
Looking for one that'l work as my phones heading back to tmobile for repair. I'm currently running bootloader 0.93.
Thanks
Mick
Also, I'm not an RUU expert, but it might be worth posting a description of the precise problem here, as someone might have some suggestions.
One other random thought: do you have an old nandroid (say from before the problem stated)? If so, and if you could get into recovery long enough to restore that, it should rule out a software problem.
Though if you can get the RUU to run that will also rule out software if the problem is still there.
Thanks for the help again mate, Unfortunately it has to be the "PB99IMG" as I cant get into htc sync to work on Gingervillain for some reason. I tried updating to gingervillain 2.8 and still no joy with the screen error so i'm thinking it may be hardware failure.
I also sourcing the "PB99IMG.zip" earlier and running it from the hboot with no joy at all. I also tried running "RUU_Bravo_Froyo_TMO_UK_2.12.110.4_R_Radio_32.49.00 .32U_5.11.05.27_release_157560_signed.zip" for hboot aswell.
One month left until my upgrade and my desire chucks it!
You won't be able to run HTC Sync on a non-Sense ROM. However, there's another way of running the RUU: boot into the bootloader, select fastboot from the menu, and connect to the computer. The words "fastboot usb" should appear on the hboot screen, and you should be able to run the RUU then.
Edit: though to be fair the PB99IMG should also work. Make sure the phone is well charged before trying it.
ERROR[140]: BOOTLOADER VERSION ERROR
Ive been getting this same error,Ive tried returning to my original gold card I used but still no luck.
Appreciate your time mate,I'm probs missing something very obvious here so bare with me lol.
I'm currently running image version 2.29.405.2 if thats any help?
you debranded your phone to a higher version than the tmobile RUU thats why you are having a problem
Run the Gingerbread RUU (this should still be supported for warranty)
or
you will need to use a gold card and use teppics downgrade utility to downgrade the rom to a slcd 2.1 rom then run the tmobile pb99img to flash back to the tmob build
we dont know why htc doesnt allow downgrading but this is the only way you will get it to a tmobile build
Does this include resetting the hboot back?
Do you mean, does an RUU reset the hboot to stock? Yes it does, however the new alpharev hboots (so assume this includes the revolutionary ones too) have write protection so the RUU cannot overwrite.
This means you have to flash the alpharev downgrader hboot first.
Ah. So should one have to send his Desire back for warranty purposes, he won't be able to simple run the official Gingerbread RUU?
So you will have to flash the alpharev downgrader first then run the ruu? Also, after flashing the downgrader, can you just turn your phone back on and use whichever custom ROM you have installed?
It's a steep learning curve that's for sure..
yes
Ah ok,
If that's the case, can I install an official Sense ROM without having to downgrade my hboot? I.e. I want to go back to official Froyo (debranded) and retain my Root access. Is there anyway I can do this? My hboot is 6.93.1002
Sorry if I keep running in circles.
Cant thank you guy's enought, After 2 days of torment I finally got it back to a stock rom 2.3 gingerbread from HTCdev - HTC Kernel Source Code and Binaries.
Unfortunatley its not solved my screen issue, My phone's booting up ok now but as soon as the screen time's out or you lock it there's no comeback it doesn't switch back on. I'll head into tmobile tomorrow and see if they'll sort it as i guess its hardware failure, Possibly something to do with the connection as the buttons still light up but no screen.
As said above thanks for your time folks,I'll get back to this topic and let you all know the diagnosis and fix.
Much appreciated
Mick
Ah ok,
youre running 6.93. that is protected (a good thing), you can flash RUU as long as this custom hboot you have is standard partition sizes (not cm7 tables etc) you can the flash recovery and flash the super user zip found on the revolutionary site
Rasta, you (and all the other regs who help us learners out) are worth your weight in gold.
Is there anyway in determining if I have a standard partition size for my hboot?
Also, to ensure I have my head around this, is this the order you are proposing?
-Download RUU
-Install/Run RUU (as HTC gave instruction to install 2.3.3 Gingerbread official release)
-I should then have STOCK 2.3.3 installed, unrooted with hboot back to my original?
I'm struggling to get my head around the hboot function.
Many thanks!
-Download RUU
Many thanks!
if your hboot doesnt have the table name at the top (in the pink writing) then its standard layout.
-Download RUU
you then have STOCK 2.3.3 installed, unrooted with custom revolutionary/alpharev protected hboot and NOT original
you would have stock recovery though.
you would have to use the hboot downgrader from alpharev to return the hboot to stock.
why would you want to do this though?
teppic76 already has built a standard 2.3.3 rooted rom that is completely based on the htc dev one
You're right, I don't need to do this and I intend to use Teppic's build.
This is just in case I need to send it back for warranty purposes etc and learning all the in's and out's of rooting.
You guys are feeding me my hunger for knowledge.
if you needed to send it back you can just flash the dev build 2.3.3 as its supported
So the hboot will not be breaching my warranty? Why is this if I may ask? It seems to me if I'm adjusting some of the core features, my warranty should be void?
Yes, the hboot would definately void your warranty. So for warranty return you need to flash the "downgrader" hboot first, so that the RUU can replace that (this is in Rasta's previous post, but I understand that there's a lot of unfamiliar stuff here).
Oh I see.
After going back through the thread and reading it again I fully understand it all. You're right, its all new ground for me but I like to think I'm getting the hang of the basics.
Thank you both for clearing that up. I now know how to unroot my phone should I ever need to...
... Touch wood I never need to!
Hi,
I have been going through as many threads/posts to gain knowledge to root my Desire and et al. I am in India and my phone is not branded with any carrier.
While I was going through the list of shipped roms list I could not exactly find the match for my build number, though there are 4 matches for the baseband version.
When I had bought it was shipped with 2.1 and later received OTA for 2.2
My Desire spec shows
- Baseband version - 32.44.00.32U_5.09.05.30_2
- Build Number - 2.13.720.2 CL274424 release_keys
Could you pls suggest which would be the correct one I can download?
The one I find for INDIA, I think that one is 2.1 version. (if I remember SUroot's explanation on naming in someplace)
RUU_Bravo_Froyo_HTC_WWE_2.10.405.2_R_Radio_32.44.00.32U_5.09.05.30_2_release_142828_signed.exe
RUU_Bravo_Froyo_hTC_Asia_WWE_2.13.707.1_Radio_32.44.00.32U_5.09.05.30_2_release_143921_signed.exe
RUU_Bravo_hTC_Asia_India_1.21.720.4_Radio_32.36.00.28U_4.06.00.02_2_release_127705_signed.exe
Thank you
Hi,
Thank you
you are branded htc india unfortunately.
its not the same is the EU WWE roms
the only thing you might be able to do is flash the gingerbread dev rom but i dont know if it works with those builds as they may not be included in the update file.
