Root Stock Wallpaper!
a5pe4
So I'm rooted and I don't have the default wallpapers. I have the live wallpapers but what I really want is that stock red background that is the default on all our Optimus V's. Anyway I can get it?
I made this wallpaper (it's called Lines And Such), and while it's not exactly like the VM default wall, it may hold you over till you find it.
This wall looks best when Wallpaperwizardrii is used to set it on crop portrait, no scroll.
http://dl.dropbox.com/u/7065872/temp/Red-LAS.png
I found it and your's is super similar! I really like that style of wallpaper but I don't know what it is about them. Something about the fading and shading on a solid color. Mmmmmm ;)
I some how got you the default wallpaper for the Harmonia ROM. SORRY!
Now do you see why I moved you? You weren't going to get much help with your problem where you were at.
I moved you here and Bam! problem solved.
But I found it myself ;) I was just hoping someone with stock could rip it
@Cammy I put the link on my 2nd post. Check it out!
I see where your coming from. But that sort of thing their not able to do. The default wallpaper is on the System which they can't access unless rooted.
You had a better chance of accomplishing you goal here. Granted you did accomplish it by your self.
Sorry about the Harmonia default wallpaper by the way.
I don't think I need all 15 but this will good to look through. You are awesome! Thanks :D
You're quite welcome. :) I figured since I was in there doing the impossible ;), I may as well pull them all out. Other peeps might want them too.
Well I think I owe you a huge apology . SORRY! I can sometimes be too helpful
Good thing I left a three day redirect so your thread would actually be in both places.
melim: if you don't mind, every now and again, letting me get your opion on non rooted topics as you are definitely the non rooted guru. Maybe just leave you a link to the post so you can give them you advice
This way a OP Gets the best advice on non rooted topics.
I don't like kicking myself in the rear. I am much better at sticking my foot in my mouth.
Maybe melim will help keep me from embarrassing myself to much.
^It's much funnier for me the way things are now, though. :p
Plus what you're asking sounds way too much like work...and I don't think I'm a guru...and there are plenty of other people whose phones aren't rooted who can follow you around and point out your mistakes...and I'm usually pissy and not feeling very helpful lately...and I overuse ellipses...:D
It's not like I'd be pleading, and begging nicely for advice every day.
Just on those rare occasions when it's not clear which forum would be best for the member that's having problems.
You really will be helping them.
If I run into a question regarding the aforementioned problem I will.
I sure hope your headache is gone by the time that ever happens again.
