Help stoopid question
blobq
Member
hi
just upgraded to 2.3.6 (kk5) from the odin site, saw some custom ROM's there, i think frankenstien?
Is there any benefits to upgrade the ROM?
im currently on:
Version 2.3.6
baseband KI3
kernal 2.6.35 7-I9100XWKK5
BUILD kk5
So-called 'Frankenstein' packages aren't custom ROMs, they are
created due to demand for Firmware with different CSC and modems and also leaked firmware packages. KIES will not recognise the firmware so you won't be able to update to new firmware using KIES unless you flash back to a firmware meant for your device first.
If you don't know whether you need a Frankenstein, it's safe to say that you probably don't. ;)
