Help Stop blinking!
Is there any possible way to get the LED to quit blinking orange constantly when the battery is low? It's incredibly annoying to have the phone flashing at me out of the corner of my eye for hours on end...
No, there isn't a setting to stop that. Aside from charging it, you can turn off the phone. Sorry dude. :(
Thanks, never thought of that. :rolleyes:
I'm not always near a charger, which actually makes things worse because the LED blinking is probably making the already-low battery drain quicker.
That tiny LED would have to flash for days to drain the battery, even if it is low. LEDs use very little power.
If we went entirely on the LED and nothing else; it would take more along the lines of Months. And that is it's just ON. Imagen if it blinks. We could see it go on for Years. lol Sorry, thought too much into it.
LEDs are designed use minimal power. And give off almost NO HEAT. They use LEDs all over the ICEHOTEL in Jukkasj
I know under menu>settings>sounds&Display there is an option to turn off notification flash LED... Not sure if it will work for a low Battery alert but here's the options
Missed Call
SMS/MMS
EMAIL
Voice Mail
Reminders* (this may be it?!)
Alarms* (or this one?)
Give it a try! :)
For me, I don't mind the fact that it's blinking. It's just that the blink is so BRIGHT! When I'm using the phone with <15% I can't even concentrate on the screen because that blink annoys the heck out of me. I wish there was a way to turn down the brightness of the LED.
