Storage Card, stupid question i know...
somanc
Ive searched but cant seem to find an answer
I want to use my 8gb micro card, twice the storage
But will removing teh default card, mess things up?
Just noriced specific files etc when connected to the computer, and dont want to mess all the settings up
I,e there is a file for photos , mp3, etc. If i put in my new memory card these folders wont be there? ? ?
Is it as simple as plugging in the new one and thats it?
Thanks
Okay leads me on to my second stupid question...
Whats the point of the phone saving a back up onto the memory card?
I mean if i lost the phone ive also lost the memory card?
How do i backup onto something more physical i.e. my pc
Thanks so much
Yes would be good if you could backup to PC using HTC Synch like I used with Nokia PC suite.
Apart from that I am loving the move from Nokia to HTC and Android
On a similar note, I think I need to format my SD card (16gb one, taken from my old WM phone with songs on etc). I just put the card in when I got the phone and now certain apps are having trouble writing to the SD card. Should I connect to my pc, back up the songs and pics etc. then format the card and put the songs back on?
Thanks in advance for any help
