NP i bolive in for the ppl by the ppl USERS are a terrible thing Systems would be infinitely more stable without them
and yes like stated above
so a permanent fix will be to install a custom ROM which requires multiple steps and can be a bit difficult if you not familiar with the process
so if you looking to ROOT the easyest way will be to use GingerBreak here is the link to the guide
http://androidforums.com/triumph-all-things-root/455603-guide-rooting-your-motorola-triumph.html
now the easyest way to backup stuff will be first for ur txt msgs use this app search on play store or click this link from your phones browser by loading this site on it
https://play.google.com/store/apps/details?id=com.riteshsahu.SMSBackupRestore&hl=en
for your call log(recent calls dialed all that) if you want to back it up if not then skip it
https://play.google.com/store/apps/...nJpdGVzaHNhaHUuQ2FsbExvZ0JhY2t1cFJlc3RvcmUiXQ..
just install run and select BACKUP onces you factory reset download again and select RESTORE(that goes for both APPS)To back up contacs just go to 'accounts & sync' under manage accounts make sure to remenber/write your account name and offcourse know ur password select your account and slect "sync Contacs' wait till is done the lil icon on the status bar should be display to know is syncing and then for your apps since you said you only have 7 you can just download then again of the play store just remenber/write which apps you already have
also i think your smart
if you think your brave enough to install a custom ROM here is a guide you can just read it COMPLETELY and see if you think you can do it
http://androidforums.com/triumph-al...stalling-cwm-custom-rom-motorola-triumph.html
if you decide to install a custom ROM and need help on picking a custom ROM just ask
