gibbs1984
Android Expert
I have Flashed the LeeDrOiD v2.2b ROM and when accessing the Stock browser it will randomly crash, it's a strange crash because normally a crash will mean that you will exit from the browser and next time it will load to the homepage, on mine though it will sort of crash but then load the page I was on, even if it wasn't my homepage, if I had any tabs open I would also lose all of those, which is how I know it's crashing.
This isn't specific to this version of the ROM though as I've had this since v1.4, when I asked in the XDA forums they said it might be to do with re-installing my backed up data, basically I went from Android 2.1 to 2.2 when I Flashed the ROM and they said that backing up data when crossing over Android versions could cause problems.
What I have done this time though is not backup anything, no SMS, no system settings, nothing! I deleted everything off my SD Card, cleared the cache, then cleared the Dalvik cache, did a factory reset, Flashed the ROM and then Flashed the radio but still this problem exists, I haven't backed up anything this time, although when I logged into the Market with my Google account it synced my contacts back onto my phone, as they're linked to my Google account somehow.
This is really starting to annoy me now but I can't figure out for the life of me why it happens, I've tried replicating it to narrow down the cause but I can make it happen one time doing it a certain way but then doing it that way again it'll be fine.
Has anyone got any ideas of how I can overcome this problem or how to Flash the ROM so that my browser will work correctly, this browser problem is the only problem I have with the ROM, apart from that it is superb.
Any help very much appreciated!
EDIT: Also, the browser can crash whether I'm connected to a data plan/Wi-Fi or not!
Albeit not as often as with the A2SD on.
