mikem0269
Android Expert
Ill try to keep this as short as I can. About 2 months ago with MikG I lost phone and text. Got a radio interferance box on the screen every time i tried to text or make a call. I wiped cashe's rebooted and it was good for about 3 days then again no text and phone. This time I just rebooted and worked again. Then I switched to digital Karma a day later and 2 days after flashing Again it happened. I wiped cashes again and was good to go untill I flashed tommys clasic It was ok for about a week Then no phone no text and got the radio interferance notice. So I decided to un root as a last resort to see if it would do it pure stock. I stayed unrooted for about a month and no issues. I was rooted with tacoroot and unrevolked so I thought I would root a little different this time and used tacoroot to roll back the h boot but then I took 1 ota to get the hboot to 2.16 then used revolutionary. Well after 3 days the problem is back Now im on the stock
4.67 build with up to date baseband 2.15.00.12.19 stock kernel. The fact that I had no problem when im unrooted makes me believe its not a hardware problem but either software or something with the misc part. that tacoroot uses to downgrade. and the fact that a reboot corrects the problem for a while. So does anyone have any thoughts on this or any other sugestions on what to try. Sory so long but wanted to cover everything. Thanks
edit: Also 3G 4G and wifi work fine when this is happening.
Guess just posting the question here fixed the problem LOL Or OCN came over and fixed it while i was sleeping:tee:
