Root Streaming Audio Fix
djl236
Member
I have a quick question, I'm running the latest FrankenROM with Sense from 8/22/2010 with the stock kernel and the 2.15 radio. How do I install the streaming audio fix? My pandora sounds terrible now. Is it done through adb (if so, can anyone type up the instructions/commands) or do I just put it on the SD card and load it through clockworkmod?
Thanks.
have you tried changing build.prop to fix it? if you edit /system/build.prop and change...
media.stagefright.enable-http=true
...to...
media.stagefright.enable-http=false
...that will fix it. at least, it did for me on skyraider 2.5.2 w/ sense. if you're running hulu as well, the streaming audio fix adrynalyne posted will cause demonic sounding voices in hulu. the change above (without applying ad's fix) will fix both the streaming audio AND hulu (again, at least it did for me).
...to...
Thanks, I'll try this tonight when I get home. Is this done through adb? I have the SDK, etc installed on my laptop, but I'm a complete noob and just getting the hang of all of this. Can you explain a little more exactly how to do this? I apprieciate it.
adb pull /system/build.prop /*wherever you want to pull it to
then change those lines with a text editor
then
adb remount ; adb push /path/to/new/build/prop /system
or make all the changes with root explorer or something similar
