Root stuck at full clock
doggydude
38
4
Noticed my phone was starting to heat up and loose battery crazy fast lately, and when unchecked setcpu, it was stuck at 1.7ghz, which was my max. I killed all the apparently open tower if it was an app, but there was no change. Even tried a reboot. Obviously running the latest umph kernel, and I have the battery percentage and power menu mod with the deodexed from.
Any help would be appreciated
Edit: epic facepalm. It said it was governed by scary, but it was actually stuck on performance that sets at full clock. Half my fault, but the rest is setcpus fault, not the kernel
I take it back. It got stuck full again on scary
Before becoming a quitter like lou61166 you should try to lower your clock speed and see if get's stuck at 100% as well. If that didn't work try to reflash whatever rom you are using. Clear cache and whatnot (first try to do it without a data wipe then if that doesn't fix it do a data wipe). If that doesn't work try to go back to stock rom and see if it stays at 100% with a normal clock. If none of that works then you might have a hardware issue. Most of the time though it's software.
Upvote 0
Quitter? ive been trying to figure out why this whole time.. I did try lowering clock, it stays at whatever your max is. I tried every governer, the only one that did anything was powersave, but thats just because it forces it to the lowest clock. I found that If i uninstalled setcpu and used nofrills (they werent both installed at the same time, before someone scolds me for that) it fixed it. I monitored the frequency with system panel, and it hasnt gotten stuck again.
Upvote 0
Are you using stock rom with a oc'd kernal or the CM7 rom? Setupcpu should not be used with CM7. Cyanogen even states it on his site. Only use the overclock settings in the rom itself.
Oh and I wasn't calling you a quitter it just I didn't want you to think that quitting was the only option which lou made it seem like.
Upvote 0
im using stock with oc kernel, waiting for cm to fix more of the problems. And it got stuck again today. Watching on system panel, its not any of the tasks open, tried killing all of them. Only a reboot could fix it.
I'm guessing its only a problem I'm having since it would be pretty major if everyone Is, so I might try stocking it and reinstalling everything.
Upvote 0
BEST TECH IN 2023
Smartphones
