Help Stuck at Recovey Mode
mohdafic
Hi,
i'm trying to flash from 4.0.3 to 4.0.4. when i tried to access the recovery mode it just show blank screen and was nothing prompt. i only see an android with a red warning triangle at his stomach. Please assist me with this issue.
Thx
I don't know your phone specifically but until somebody with more knowledge comes along, to me that sounds like a typical stock recovery logo. Are you trying to use an update.zip? If so, perhaps try holding volume up + the power button while on that screen and see if it brings up a recovery menu. Another guess on the key press combo but its a pretty common one.
thanks for your reply..
i have follow below steps yet nothing changes.
Power off.
Hold volUp + power for 2 seconds.
Press volDown twice.
Press power.
Wait 10 seconds for it to reboot into recovery.
Press power + volUp.
Press volDown.
Press power.
Press volDown again.
Press power.
It should now be installing. Give it about 10 minutes to make sure it's done.
Pull the battery to power off.
Replace the battery, and power up.
yes im using update.zip file
Power off.
Press power.
Wait 10 seconds for it to reboot into recovery. Is this where u see the red triangle?
Press power + volUp. May be just an issue of semantics but press and hold volume up and then press and hold power also. This is where I would guess the menu would come up.
Press volDown.
Press power.
Press power.
My thoughts in bold. You may be doing it right and are having some other issue. Just wanted to make sure it wasn't a key press problem.
From what i know ,there is a problem with the stock 4.0.3 recovery - you can't enter ! ...try to wait for 4.0.4 OTA ,or if rooted ,flash CWM
