Hello guys,
Here I big problem for you to solve... (big cred to the one who does).
I "updated" my HTC Desire with Unrevoked to root it.
unrevoked
A few days later my phone reminded me that a new update for Android was available. When I tried to install the new system Clockwork mod refused. So I formatted my phone to the factory settings thinking that this would delete Clockwork mod, which it didn't... Anyway, when I tried to do the update again I got stuck.
When I start the phone i get to a prompt:
Bravo PVT3 SHIP S-ON
Hboot- 0.93.0001
Micropop-051d
Touch panel-SYNW0101
Radio-5.11.05.27
Aug 10 2010, 17:52:18
It lets me navigate through the volume buttons. I get 4 choices:
1. Bootloader, 2. Reboot, 3. Reboot bootloader and 4. power down.
The last three doesnt do anything but reboot the phone.
If I choose the first "bootloader" it loads and says:
SD Checking...
Loading... [PB99DIAG.zip]
No image!
No image or wrong image!
Loading... [PB99IMG.zip]
No image!
Afterwards I get 4 new choices:
1. Fastboot (takes me back to the first 4 choices)
2. Recovery (takes me to Clockwork mod)
3. Clear Storage (delete all user data? Yes - reboots)
4. SIMLOCK - Gives me the following message:
FAT32 init OK
OPen MCCMNC file fail
Open CID file fail
Process done, reboot device? YES
When I choose recovery everything reboots and I se the htc logo against white. Then i get to a new prompt:
ClockworkMod Recovery v2.5.0.7, where I get 8 new choices:
1. Reboot system now (takes me back to the first prompt screen)
2. apply sdcard:update.zip (it cant update saying no such file or directory)
3. Wipe data/factory reset (wipes everything)
4. Wipe cache partition (wipes cache)
5. Install zip from SD card (cant find file, can enable/disable signature and script asserts)
6. Backup and restore (cant find isd-ext.img)
7. Mounts and storage ( I can mount and format
8. Advanced (I can reboot and wipe a couple of things)
When I plug the phone into a MAC nothing happens, when I plug it into a PC I hear the popupsound but nothing is shown.
When I but the microsd-card into a card reader it asks me to install drivers for Android 1.0. I found the drivers and installed it. Two removable disks are shown, but when I click them it says that I should but a disk into it.
Damdamdam, how do I start the phone again?
unrevoked
Hboot- 0.93.0001
Micropop-051d
Radio-5.11.05.27
SD Checking...
No image!
No image!
FAT32 init OK
Open CID file fail
