brickedfone
Successfully rooted and unlocked sim. I then wanted to bring it back to normal, unroot and lock up the bootloader. I think I made a gold card, instructions were confusing, and all of the RUU I tried didn't load up. So nothing was working. Then I remembered I backed up the original interface before rooting, so I just recovered that from flash card. I don't know if that unroots it, didn't do anything other than hit recovery and selected the file. So far success, went back to factory interface. This is where the problem began, I then went to lock up the bootloader. I did the cmd in fastboot folder, and typed "fastboot oem lock". It said it failed and then the next line it said it succeeded. Phone automatically rebooted and the bootloader showed "Relocked" at top. But now it won't boot into the regular interface, just boots back to the bootloader. And I don't have a recovery option. Just "Bootloader", "Reboot", "Reboot Bootloader", and "Power Down". Taking out the battery and adding it again doesn't do anything, done that several times. Need help.
