Hi, egh, I messed up.
I rooted the phone a couple days ago, and then last night flashed the latest Cyanogen Mod. I reinstalled all my apps using Titanium Backup, then started looking around for themes. I misread some instructions for the Incredible Revolution theme ([Theme] INCredble REVOlution [9/10/10 Theme Update! -- CM6 Beta Re-Release] - xda-developers) and used ROMManager to download it from the Virtuous section. It asked me if I wanted to backup and then wipe data, like it does when you're flashing a ROM, and I clicked yes. It did it's thing and then rebooted. It got past the white HTC Incredible screen (a modified one), started to go into the CM Android on a skateboard boot animation, and it's stuck there. I can't even get into hboot or get it to recognize from my computer (I have a Macbook, if that makes a difference). Eek. Help! This problem looks different than the other bootloop problems out there
Thanks
Thanks
