Root stuck in fastboot(blue screen)
nyrkid21
Hey can anyone help me out. My phone is stuck in fastboot mode with the blue screen after i tried to root it and install velocity. Can i have some advice on how to fix it? Thanks
Ok - did you download the files to your C:/ drive?
If so..plug the phone into your PC and connect.
Open the cmd prompt on your PC (search for it if you need to).
Once cmd prompt is open, type: cd c:\android\sdk\tools
Type: fastboot reboot
Your phone will reboot and if you installed the ROM correctly, it will load up just fine. Open up your ROM manager and re-flash the recovery and you should have no problems. Post back if you still have issues.
Once you are in the recovery, you need to do a wipe the data (factory reset), wipe the cache and dalvik cache as well. Then try re-installing your ROM.
I too flashed velocity .03 and had major problems... prolly bc i did it wrong. but at this point i have gone into clockwokmod recovery and wiped everything out. when i "reboot system now" after the LG screen, the blue screen comes up saying "fastboot mode started. i have no idea what to do. I plugged my phone into my comp to download other zips to upload but i cannot connect to my pc. please help! thanks
In clockwork there should be a mount usb option somewhere been awhile since I have used clockwork.
update: found this in online. hope it helps
in clockwork recovery you will have
-reboot system now
-apply sdcard:update.zip
-wipe data/ factory reset
-wipe cache partition
-install zip from sdcard
-nandroid
-partition menu
- advanced
Partition menu gives you thes options:
mount/data
unmount/ cache
mount/ sdcard
format system'format data
format cache
format boot
mount USB storage
-reboot system now
-nandroid
-partition menu
- advanced
mount/data
unmount/ cache
mount/ sdcard
format cache
format boot
mount USB storage
trying this now!
I had the exact issue w my ally. pc wouldn't recognize phone, bluescreen of death. I've accepted defeat. Verizon was merciful and New replacement on the way!
